Does anyone know how to get all the walls in the properties pallet (eg.. Gerneric-250, Gerneric-300 etc) Ive downloaded this software on my laptop and when I design at University it it has all the other options.
hello, i think you didn't install the content library. follow this process but try to switch off all you anti virus program and firewall before downloading and installation. hope it helps. thanks
It would be worth learning how to create your own walls - this is a basic function and one you'll need to learn if you are going to use it constructively moving forward.
There's plenty of stuff out there to learn from so you shouldn't be short of material.
Wall types are not part of the content libraries, except in the sense that they may be already created in a template file.
To create a new wall type, activate the wall tool, choose an existing wall type, click the duplicate button, give your new type a unique name, and edit the structure to reflect what you want.
You're learning Revit at a university and they don't teach you this?
