walls types schedule summary formula
BIM_Dreamer
Message 1 of 11
BIM_Dreamer
i have 5 storey model with different types of walls. how to create a wall types summary of total length every floor in wall schedule. for example i have 300 thk rc wall, 100mm thk alc wall in every floor so i want to show them combine total length each type of wall of every floor.  and how to create formula. thank you
Replies (10)
Message 2 of 11
BIM_Dreamer
something like this, any suggestion. thank you
Message 3 of 11
constantin.stroescu
You mean something like this:
Constantin Stroescu
Message 4 of 11
BIM_Dreamer
thank you for your reply, i have already that one, i need a combined wall types with total length in schedule, something like this. thank you
Message 5 of 11
BIM_Dreamer
something like this in wall schedule. thanks you
Message 6 of 11
constantin.stroescu
Then, like this:
Constantin Stroescu
Message 7 of 11
BIM_Dreamer
Yes that's the one please show me how you did this. Thanks
Message 8 of 11
constantin.stroescu
  • Fields : I used the Family and Type field in order to place Type Marks to wall in a quick mode...Later this Field is hide..
  • I use Filter in order to isolate a Level..
  • and then Sorting/Grouping - Sort by Type Mark and Base Constraint ( the Level on which the wall is placed) . No Grand Total , No Itemize Instance
  • Formating:
    • as said before the Field Family and Type was used only for a quick selection, that's why I'll check it as Hidden Field (not to be shown)
  • Base Constraint - I can change the name into LEVEL
  • Type Mark needs no other settings
  • Length Field
    • check Calculate Totals
  • you can also change the Units here
Constantin Stroescu
Message 9 of 11
BIM_Dreamer
Sorry just realise your sample is not what I want. For example in level 1 you have W200 and the length is 14.55 and you have three same types in level 1 so the total length is 43.65. So I want to show like this in wall schedule W200 TOTAL LENGTH 43.65. I hope you understand what im trying to achieve. Thank you
Message 11 of 11
constantin.stroescu
Constantin Stroescu
