Every time I am drawing a wall in this revit file, the properties are defaulting it to the wrong level. So for example, I am on my Ground Floor, but the walls keep defaulting to base constraint being on the First Floor.
After this happened I checked the work planes for each level and for some reason they were all set to the floor level directly above. I changed them to the correct work plane levels, but the properties bar is still defaulting to the wrong level when i go to draw a wall.
Why would all my work planes have been screwed up? This is the first time it's happened......
I will attach the file.
I hope I am making sense!
