I am getting an issue with Wall Joins and base extension distance
like this previous issue mentioned
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Base-Extension-Dis...
i am using revit 23 and what is happening is exactly the same
currently i need to update every join manually to mitre
I have seen this before and there are a couple of workarounds there but just to make sure we are not overlooking some obvious Revit traits.
Are they placed with "Disallow Joins"...select the wall and click the T sign to re-allow Join
Are you using Unlocked Layers with Base extension?.... On the Ribbon
Or Alternatively:
NOTE: If you disable Join on both walls >>> You will need to manually invoke Join Geometry tool
Hey Thanks for the Reply
They are not placed with "Disallow Joins"
yeah i have the brick and cavity unlocked while the stud is locked. so it works with out slab drop down.
(have tried only brick unlocked but has the same issue)
Yeah i know i can update every join manually. but i shouldnt really need to do this.
In my original post i had a linked issue report from Revit 2016 with this issue.
So i assume its just a bug and i will need to do this workaround until its fixed. Hopefully dont need to wait another 7 years.
