Walls Lose Color When Structural Framing with 100% Transparency Overlaps (Revit 2025 PDF Export Issue)
Hi, I'm trying to troubleshoot an issue I came across this morning. I’m trying to understand why, when I have a structural framing element set to 100% transparency (so that only the outlines are visible) placed on top of a wall set to 60% transparency with a solid color fill, the wall loses its color when exporting to PDF using vector processing (In Revit view and raster processing the produce normal results).
This issue started occurring in Revit 2025. I opened the same file in both Revit 2024 and Revit 2025 — in 2024, it exported to PDF as expected, but in 2025, the walls lose their color whenever structural framing elements overlap them.
Please check the attachments.
Is this a Revit 2025 issue? Has it been fixed in Revit 2026?
