Walls intersect in PLANS but NOT in 3D
Hi all, ever happened to you that walls intersect in the plan view but in the 3d they don't?
Here is both views attached. Thanks
RDAOU
@Anonymous
This is either a separate wall or you have split the wall into parts...What you see in the plan view is the upper section/wall where the cut plane is set (I am assuming at 1200mm from floor level.
It is the same issue you are having with the walls from your other posts...I would like to suggest...if possible...that you post your revit file so someone can help you fix the problem properly and explain where the mistake is
Post the file as @RDAOU said or post a pic of how your walls are assembled in the wall settings.
