Crash creating view filter for grid parameter (2017 regression, worked in 2016)
boostyourbim
Message 1 of 9
boostyourbim
Attempt to create a view filter for the Grid category.
This worked in 2016
This is not specific to any geometry - happens in an empty file
' 0:< DBG_WARN: One of the given rules refers to a parameter that does not apply to this filter's categories.
'Expect a soft crash after this warning.
'ApplicationException is being thrown on behalf of the function <void __cdecl ParameterFilterElement::setRules(const class Arr<class FilterRule *> &)>. Dump file: C:\Users\harry_000\AppData\Local\Autodesk\Revit\Autodesk Revit 2017\Journals\journal.0177.0001.dmp: line 1263 of d:\ship\2017_px64\source\revit\revitdb\gensrc\ParameterFilterElement.gen.cpp.
' 0:< TaskDialog "A serious error has occurred. The current action has been cancelled. It is strongly recommended that you save your work in a new file before continuing.
Replies (8)
Message 2 of 9
boostyourbim
Message 3 of 9
Having the same issue here, have you found a solution or gotten a response?
Message 4 of 9
boostyourbim
No update that I can provide. Does Autodesk monitor these forums and ever acknowledge bugs?
Message 5 of 9
Doesn't seem like it, you certainly gave them enough information.
Message 6 of 9
michael.coviello
Autodesk Support
Autodesk Support
Hello-  We just want to inform you that our engineering team is working on this issue.  Thank you for the description and video.  Our engineering team has diagnosed the issue and a fix is scheduled for a service pack.
Michael C
Technical Support Specialist
What's New in Revit 2023 | Autodesk University | Revit Blog
Message 7 of 9
Thanks Michael, looking forward to the patch.
Message 8 of 9
boostyourbim
Looks like this was fixed in Revit 2017 SP 2
This list represents the reported issues resolved in Autodesk Revit 2017 within build: 20160720_1515.
http://revit.downloads.autodesk.com/download/2017RVT_SP2/Docs/RelNotes/AutodeskRevit2017-SP2ReleaseN...
Improves stability when associating a view filter with grid filtering based upon project parameters.*
Message 9 of 9
Awesome, I'll have to get that rolled out.
