Walls do not connect
I'm experiencing problems with vertical walls.....Revit doesn't want to connect them!?
...tried to stretch them manually but nothing happens!
Any help would be highly appreciated!
Regards!
cbcarch
Looks like the walls are interrupted by a floor or roof? You could try using Join Geometry.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
@cbcarch
thank you!
I managed to connect the walls by "edit profile".
Regards!
How did you answer this question when you placed the floor. "Yes"?
Try Detaching Wall.  Not "Edit Profile".
@Anonymous wrote:
@cbcarch
thank you!
Regards!
I guess when you Edit Profile, it asks to Detach all Top/Base of the wall so that you can make it whatever height you want without actually having to edit the profile.
