Walls - control the thickness of the exterior lines
mairh_tsek
mairh_tsek
Hello all,
I have created two different walls in the same level. How can I control the thickness of the exterior line of each wall?
Thank you in advance!
ramsuhas7
Try Changing the Projection and cut line weights in the highlighted section in image.walls.PNG
rimacoca
Creat a filter by wall type.
Help Page Revit 2018 - Creat a filter
A KUDO is always welcomed; However, when the above answer helps and/or clarifies your query; kindly mark this reply.
Submitted ideas
/ All Revit up dates
Projects BIM Integrated Services
mairh_tsek
It seems that the filters is the answer.
When I change the Projection and cut line weight in Object Style nothing happens..
If nothing happens when you change the Object Style Projection or Cut Line Style, then you must have Graphic Overrides controlling them in the View.  But, I agree: we define filters and assign them to the views for this kind of thing.
Object Styles control the graphics of categories, not individual types or instances.  Using Filters is definitely the answer.
FAIR59
You probably have Cut Line Styles checked on the [ Override Host Layers ] panel in the Visibility Graphics Dialog.
The Line Thickness is then defined for each layer function.
