Walls appearing differently in 3D view
sydney_wright
Observer Observer
sydney_wright
Observer
Observer
On my Revit model, I have a design where the exterior walls are the same type, but are showing up as two different colors. I double checked everything and they are the same exact wall type. There is no paint on them either, and I have also tried to just paint them the same color and my paint will not show either. I do not know what the problem is.
mhiserZFHXS
What kind visual style are you showing? Could be shadows.
Or do the walls have different materials on each side? Maybe you need to flip one of them?
Are they under the same phase?  If not, set the view phase filter to Show Complete.
Have you tried another 3D View?  If it's the Default 3D View, you can Delete it and recreate it by pressing the lil' house icon button on the QAT.
...my guess: Graphic Overrides by Element.
sydney_wright
Observer
Observer
Yes, I did indeed need to flip the walls. When I tried it before, it did not show any change but I tried again and it worked. Thank you so much!
jason_coulter
Observer
Observer
remove paint tool under modify tab and click walls to remove surface paint.Removal.jpg
duyen_nguyenCYJW3
Community Visitor
Community Visitor
It works well. Thanks for your support.
