Wall with Different Width
2 REPLIES 2
344 Views, 2 Replies
Hello Good People,
                I am trying to model the wall in the first figure.   The concrete wall is of different length on each side at lower end.  I Modeled a typical basic wall with looks something like the second figure. Is it possible to angle the concrete wall so that one end is longer than the other? These are sections in plan. Thank you.
2 REPLIES 2
Add an in-place void to trim the end of the wall to the angle.
in reply to: ToanDN
Thank you for your suggestion. I went on and explored this functionality but it was after going through your older posts that I was more clear about the process.
