- Mute
- Permalink
- Report
Hello everyone,
A bit of weird one which I cannot figure out. It might be a simple thing and brain is buffering as this is a Friday.
I am having problem with visibility of a wall in two different views. I have a 'working view' that shows the element and a 'drawing view' for the sheet where I cannot see the element. The 'drawing view' is done with a plan region if that is relevant.
Here is what I tried so far:
- lightbulb trick. Go lightbulb in the drawing plan, go to working plan and select elements, and as you can see in the attached screenshot the element does not appear so I can select unhide at the top.
- tried switching discipline to architecture/coordination . Still not shown
- made a View Template based on my 'working plan' and tried to apply to 'drawing plan' and that did not work
- tried to set the view range of the plan region in the drawing plan to the same as the view range in the working plan ....
- no filters set
- elements are set in the same phase
Running out of ideas. Any thoughts ?
