Wall sweeps - Sweeps at the end of the wall & hiding sweeps when joining walls
daniel.carreiro
daniel.carreiro
Hi. I have 2 very specific questions regarding wall sweeps which I can't figure out how to solve.
This is the wall's structure I'm using:
QUESTION 1:
How to make the wall sweep go around the end of the wall which is represented in red?
The wall finish is at the end of the wall but not the wall sweep.
QUESTION 2:
How to eliminate the wall sweep in this situation when 2 walls are joined?
Thank you.
For end wall sweep return, use Modify Return tool.
For intersections, split the wall.
daniel.carreiro
thank you
