I have a wall that has some sweeps that are not visible in elevation because there is a wall layer that has a variable thickness that cannot be changed it is currently at 5/8" and needs to be reduced so it is less thick than the wall sweep otherwise it is covering the sweep. How can I reduce that layers thickness. See attachments
In my opinion ,there are a few possibilities:
Constantin Stroescu
I was only able to change the thickness of that layer by clicking modify in the edit wall structure and clicking the vertical lines and changing the dimension.
If I "use an offset for the Profile in Edit Assembly -Setion" then it will not be correct in the section detail view
