Wall spanning multiple levels not showing on each level
Hi all.
I am having an issue with my Revit model where I draw a wall on the bottom level and have it span up to the top level.
The issue is that some walls appear on each level and some dont.
I have attached screen shots that I hope helps.
ennujozlagam
first check your wall, please see attached sceenshot
second check your if there is constraint assigned.
third post screenshot here for better understanding your issues. thanks
Some may attach to a floor above. Select all, detach top /base, and detach all.
Sounds like a View Range thing to me.  Got some pictures?
