Apply Revision Cloud to all sheets
amirhossein.jafarii
amirhossein.jafarii
I have to submit a project and I revised a part of the drawing and I add a revision cloud.
revision date/number only shown in the sheet I created the revision cloud.
1- How to apply the revision number/date to the other sheets? without copy/past the revision cloud to all sheets and turn their visibility off?
2- also when it shows the number, it doesn't show the triangle around the number. it shows the number without the triangle. to put that triangle around the number?
I appreciate if you can help me.
Download pyRevit and use one of its tools.
amirhossein.jafarii
Thank you for the response. your solution sounds like a good idea.
but how do I do so without intalling a plug-ins?
Thank you
Open each sheet and ...
