Wall Settings representation
6 REPLIES 6
amirhossein.jafarii
677 Views, 6 Replies
amirhossein.jafarii
Hi All,
I have two plans. One is the basement and the other one is the second floor plan.
As you can see in the upper level walls are grey and lower floor is white. how do I make the basement floor white?
Both have the same settings and wall types are the same.
Thank you,
Amir
Hi All,
Thank you,
Amir
Tags (2)
6 REPLIES 6
Visual Style: Hidden. Detail Level: Medium.
amirhossein.jafarii
Didn't worked out!
Didn't worked out!
It could any number of settings.  Create a View Template from the "Good" View and assign it to the "Bad" View.
...or just post the file.
amirhossein.jafarii
sure!
I Have attached the file.
sure!
Right Click on the Main Level Floor Plan View and press "Create View Template from View" and follow the rest of the prompts to finish creating/naming the Template. Go to the Basement Level Floor Plan and press View Template under the View's Properties, locate the View Template you just created and assign it to the Basement Level View.
Here's what's going on in the Main Level View
amirhossein.jafarii
Thank you,
Thank you,
