Wall schedule and get wall type's structure layers
Message 1 of 9
How can I get wall type's structure layers in a list or schedule?
for example
wall #1 |  DRAINAGE BOARD, MOISTURE BARRIER, RIGID INSULATION, 2"x4" WOOD STUD, R12 F.G. BATT INSULATION, G.W. BOARD INT. FINISH
Replies (8)
Message 2 of 9
Material Takeoff Schedule or Parts Schedule
Message 3 of 9
it doesn't work properly. see the attached revit file
I want to see something like this
Message 4 of 9
A Material Takeoff Schedule. Include Parameter Fields for Materials (i.e. "Material:Name", "Material: Description, etc.)
Message 5 of 9
daniel.jl.9443
Hi  barthbradley,
How do you then sort the materials by the correct layer order of the wall?
Cheers
Message 6 of 9
I have the same problem not yet solved. Moreover I can't show nor in the material schedule neither in wall legends,  thickness for each layer
Message 7 of 9
Create Parts and schedule Parts.
Message 8 of 9
For our projects we are using a Revit app that extracts all layers of the wall automatically and present it in PDF.  It has a description of all the materials and the thickness of each layer. Have a look in the Autodesk Revit App Store, it is called Wall Type Schedule.
Message 9 of 9
luisPDAN6
This is exactly what this app is doing.  It extracts all they layers and their thickness and lists the assembly.
