Wall Reveal
Wall Reveal
KraiggC
Message 1 of 17
Wall Reveal
KraiggC
Is there anyway to split a reveal? I can place multiple reveals over top each other and move the ends, but it's extremely time consuming. I've attached an image displaying my end goal.
Replies (16)
Message 2 of 17
Why would you need to split the reveal? Split the wall. Or am I misunderstanding?
Message 3 of 17
KraiggC
it's the vertical reveals i'm trying to split.
Message 4 of 17
@KraiggC
Create one Reveal, grip edit to shorten it, then copy or array.
Message 5 of 17
loboarch
From the image you posted, it looks like a pretty regular pattern. I might try and do this as a curtain wall, where the reveals are the mullions.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 6 of 17
Same difference. Split wall vertically or horizontally and place vertical or horizontal sweeps at those split sections. No?
Message 7 of 17
KraiggC
It won't let me copy the vertical reveals due to the irregular shape of the wall. The curtainwall idea sounds like a good one. My current work around is just a stacked wall with sections at the different heights I need.
Message 8 of 17
loboarch
Here is a pretty crude version I spent about 5 minutes making.  I edited the profile of the wall once done because your example had some kind of non rectangular shape to the wall.
Jeff Hanson
Revit Help |
Message 9 of 17
Curious. It won't let you copy vertical reveals because the wall has an irregular shape? But reveals are basically hosted voids. They should copy and cut off at the edge of the wall profile. Can you post an example rvt?
Message 10 of 17
KraiggC
Thats awesome. Thank you so much. Curtain wall is definitely the way to go.
Message 11 of 17
Interesting Jeff. If this is the condition, then I'm on your side with the curtain wall idea -- if that LOD is really required.
Message 12 of 17
You can array or copy on an irregular shaped wall just fine.  Just uncheck Constrain box.
Message 13 of 17
@KraiggC: But I don't think @loboarch is using a curtain wall in his example. Maybe Jeff can clarify?
Message 14 of 17
loboarch
My example was made with a curtain wall. Made the general unit size in the wall type, then used add/remove segments to create the staggered pattern. Then changed the thicknesss of the panel. Then swapped to use a smaller mullion.
Jeff Hanson
Revit Help |
Message 15 of 17
I agree that using curtain walls is the better choice when the pattern is typical and repeating.  Plus, the panels are under a different category so you have more control over the graphic such line weight and color.  One beef with using reveal is that the reveals sharing the same object style with the walls themselves so you need to use linework tool if you want them to look different.
Message 16 of 17
KraiggC
Thank you all for the help. This is for a rendering, so it's construction usage won't be an issue.
Message 17 of 17
"This is for a rendering, so it's construction usage won't be an issue."
