Wall reveal wrong orientation
octavio2
octavio2
Added cast in place wall reveal on top of a parapet wall with several 90 degree turns using the instance sweep.  Some of the reveals have the wrong orientation, but after completing the addition and selecting them and they becoming selectable blue in color, all the reveals in a chain are selected I do not see any arrows or anything like a control handle to change the orientation of the reveals that have the wrong orientation.
Question; Why I do not see any control handle to modify the orientation?  Or another way to ask the same question:  How to change the orientation of one of the reveals with the wrong orientation?
Thanks in advance.
Can you miter corner of walls hosting reveal?
Do you have a blue dot at end? If so, can you pull it forward a tiny bit and then successfully activate Modify Returns?
