wall properties Top Constraints and Base Constraints not working
I have a project that was initially built in Revit 2014 on a different computer.  I recently downloaded Revit LT 2018 to my personal computer and I updated the project to 2018.  When I open this project (or even a template project from the start screen) on my personal computer/2018, I cannot change the Top Constraints and Base Constraints of the walls.  The drop down does not work, see image. If I open the project back up on the other computer I can edit the Top Constraints and Base Constraints of the wall.  I also cannot select the level at which to start and stop a stair.  I feel like there is a bug in the Revit LT 2018 that I downloaded (I have the 30 day free trial downloaded from autodesk).
JacobDSimpson
Try purging the file, maybe you have a buggy family in Revit 2018 that it doesn't like. Can't think of anything else sorry.
kadmonkee
when updating model to newer versions it is always a good approach to do this sequentially.
skipping version will ultimately cause issues.
it also allows you to confirm the upgrades are stable and ready for the next version.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
