WALL OPENING
WALL OPENING
Mohamed_Arshad
Advisor Advisor
Message 1 of 8
WALL OPENING
Mohamed_Arshad
Hii Geniuses,
         I create a normal wall first and edit the profile, but the old profile of the wall still displaying, how to hide the old profile of the wall. Please giver hands to sort out of this problem.
i attached the reference image below kindly find the attachment.
Mohamed Arshad K
Software Developer (CAD & BIM)
Accepted solutions (3)
Replies (7)
Message 2 of 8
MostafaElashmawy
I think that you have two walls in same place.
Mostafa Elashmawy
Message 3 of 8
Mohamed_Arshad
Hiii,
Thanks for your reply, But it is single wall the profile which you're seeing is first i draw like that and then by using edit profile i edited the whole into gable roof profile still the old profile is displaying. please fix this issue
Mohamed Arshad K
Message 4 of 8
MostafaElashmawy
Can you share the model.
May be you can save as and keep only the wall with the roof and share it.
Mostafa Elashmawy
Message 5 of 8
Mohamed_Arshad
ya sure,
i attached the file below, kindly find the attachment
Mohamed Arshad K
Message 6 of 8
MostafaElashmawy
It's not an opening.
Revit is showing you the original limit of the wall when you select it. That's a usual behavior.
Mostafa Elashmawy
Message 7 of 8
Mohamed_Arshad
hiii,
thanks for detail, But it possible to hide that limit. Our customer asking to hide that original limit.
Mohamed Arshad K
Message 8 of 8
MostafaElashmawy
In that case, don't use edit profile.
Reset the profile. Then select the wall, click attach then select the roof.
it will take the shape of the roof.
Mostafa Elashmawy
