Wall Opening Grayed Out
Trying to place some wall openings in these walls in blue. Any idea why the wall opening button is grayed out?
Did you edit the Profile?
I eneded up selecting "reset profile" and everything worked out.
...or you could have just included the opening in the Edited Profile Sketch.
Does not work with framing,.
Huh? I do it often.  Can you elaborate?
I used Metal Wall Framer to detail framing. Their pluggin does not read openings drawn into the profile. It relies on the width and height parameter of the object cutting the wall like door or window.
