Wall Opening Cuts at an Angle
PhilvK
Advisor Advisor
PhilvK
There is something in my model that is causing one side of a wall opening to cut at an angle, see below. I can't see anything in section or anything that is hidden. The angled cut does not occur when I copy and paste the visible elements to another location or file, Any ideas what may be causing this or what to look for?
Some demolished existing wall?  Set the view's phase filter to Show All or Show None and see.
PhilvK
Tried that, don't see anything. It doesn't happen though when I create the opening by changing the wall profile.
What did you create the opening with then?
PhilvK
I created it in plan using the wall opening tool, the one where you select the wall then pick 2 points for the opening.
Share your file here.
PhilvK
Can't share because it contains someone else's proprietary information, but it seems to be working now. I erased the opening created by profile (in an elevation), and then used the wall opening tool. I don't get the angled edge anymore. Go figure.
