Hello everyone,
For some reason the wall I am trying to edit is acting weird, it will not connect properly on two sides.
This is a wall that I relocated after having edited its profile to follow a sloping topography.
Please note, as in the screen shot, I have deleted the edited profile and made sure all of the top and bottom constraints match, but the wall is still acting weird and not connecting.
After resetting the profile, this is the appearance of the wall for some reason:
What is the best way to fix this? Also, after I get the walls to connect properly, should I use "edit profile" or "wall opening" to create the slope again?
Thanks!
Solved by micah. Go to Solution.
have you check the walls if there is attach top/base and try to detach? thanks
strange.. anyway can share the wall file, (cut and paste in the new file) so we can check? thanks
try to go to plan view select the wall and disallow join first and then use trim/extend to the corner?
turns out to resolve when I cut and paste in the same position... now I have to redo the profiles once again!
Thanks!
Non-structural existing curb that we are using for a newly rebuilt deck and pergola. Just placing some non-structural screens and walls on it, engineer says we are fine.
Thank you for your help!
Thanks for the tip. We didn't try it because we did the cut/paste thing first. Will keep this in mind though!
If you want to stick with editing profile then Disallow join and use Join geometry manually after done editing it's profile.
