Wall Niche/void error
n10215441
Observer Observer
n10215441
Observer
Observer
When going through this step by step process below it seems that I run into an error every time.
The error most of the time is: Instance of in-place family is not cutting host. (I cannot see that the initial line not being connected to the wall that I am cutting the niche out of). I am using Revit 2019
Architecture - Model line - square drawing tool
Component - Model in place - Walls - Name
Extrusion - pick lines - hover over top line - hit tab once - highlights all lines - zoom in and lock - click green tick
Properties - 50.0 - void - apply - click off
Are you cutting the Wall before closing out of In-Place Editing?
Use Cut Geometry to cut the wall BEFORE you finish the in-place family.
n10215441
Observer
Observer
From changing the extrusion to 50mm I am then going straight to the cut tool but even then the rectangle which I am trying to cut is highlighted orange.
Doesn't sound like it is in contact with the Wall it is supposed to Cut.
Change it to -50 mm so it goes into the wall.
...or, move the wall closer to the void.
he, he.
