Wall mounted rail not returning
leah_coley
leah_coley
Community Visitor
Community Visitor
Hi there,
I am trying to draw a wall mounted handrail and it will not return to the wall. What would be the best way to fix this? Please see images below.
Basam.Yousif
This is Autodesk content model has a few good examples you might find helpful.
RDAOU
@leah_coley
Technically it should work with the top rail unless the values of the fillet radius, the clearances, the diameter of the profile with the length of the extension or some other parameter are not matching for one another. Once cannot troubleshoot without you posting the stair/rail for checking. Copy/Paste it to/from clipborad in a blank file and post it
If you cannot upload the file and cannot get the top rail to work, Try using Handrail 1 without the Top Rail see if the extenssion/wall return for that works
kadmonkee
have you tried edit sketch and add the return?
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
