Wall Mitre Joint
Wall Mitre Joint
eddyloy2k
Message 1 of 17
Wall Mitre Joint
eddyloy2k
Dear sir,
Can I set the wall joint to mitre instead of butt joint? Please help
Replies (16)
Message 2 of 17
Revit has a tool for this...
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
Look on the Options Bar when you select your existing member joined condition, and you'll see the available alternative joins that are available for that condition chosen (e.g. Butt, Miter, Square Off)
Message 3 of 17
eddyloy2k
I prefer to set the default wall joint setting to mitre joint instead change them individually after placing. It is a lot of work to do. Can I?
Message 4 of 17
Sahay_R
Unfortunately - no. However you can select and change multiple junctions after the walls have been placed..
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 5 of 17
What is the reasons you always want miter joints?  Is there a particular construction technique/ building materials you are doing?
Message 6 of 17
@eddyloy2k: I was pondering the same question as @ToanDN. Personally, I dislike mitering, and do it only out of necessity, because it can cause other frustrations and issues.  Just Google it and you'll understand.
...nor do you see much mitering in the field (e.g. real-world).
Message 7 of 17
eddyloy2k
I need to schedule the surface area of wall.
Message 8 of 17
You lost me. How does that relate to wall miter?
Message 9 of 17
Do you use Roombook Extension?  It is exactly for that.
Message 10 of 17
eddyloy2k
Outer surface area will become less
Message 11 of 17
Oh, think I get it now. Well then, looks like mitering is necessary. A suggested workflow would be to isolate your exterior walls in the plan view, and use the Wall Joins tool to do a multiple select so you can do all the corners simultaneously. Are you familiar with how to do this? Just activate the Wall Join Tool, place a window on one corner and hit the tab key once. A Wall Join window will be placed at every corner around the perimeter. Change to join condition to Miter and every windowed corner with get the miter-touch. Doesn't work 100% of the time, but if it does, it beats the heck out of changing each corner individually.
Message 12 of 17
Nice technique.
@eddyloy2k do you realize the area of walls with inner corners are still incorrect?
Message 13 of 17
 @ToanDN: if he miters inside and outside corners, the area will be correct.
Message 14 of 17
I have tried that and it is still wrong. The thicker the finish layer the worse result.
Message 15 of 17
Yeah, that's because it is measuring from the center of the wall. Anyways, like I said before, I avoid mitering like the plaque. So, I'm just the messenger here, not the preacher. I stated a disclaimer upfront.
Message 16 of 17
eddyloy2k
Dear sir,
What is Roombook Extension?
Message 17 of 17
eddyloy2k
have it applied to inclined wall? I can't indeed. am i wrong?
