wall material doesnt seen(componen- model in place)
i created a sloped wall with component-model in. i choose the material for this wall but the material doesnt seen in render.
Did you select the solid in model in-place editing and assign the material?  Is the wall under the current Phase?
i had selected just solid extrusion and i drawed the wall after that i select material
when i select the material before drawing, it worked. but i drawed many walls without selecting material, cant i change the material now?
...so your workflow was:
1. Start In-Place Component
2. Categorize as Wall
3. Created an extrusion
4. Assigned a material
5. Close out of In-Place Component
6. Render view with In-Place Component
7. RESULT: In-Place Component Wall doesn't render as expected.
Have you checked to see if the Material's Render Appearance settings are correct?
Do other element's using this material render as expected?
roxanaacaplan
Community Visitor
Community Visitor
Hi, I have a similar problem and my workflow was as you described, what can I do?
