Greetings,
I'm trying to figure out a way to get the correct wall length once it has attached to a wall. I need to do this since it it gives out incorrect length. Also is there a workaround in dynamo to solve this issue.
Please refer to the screen shot to just a better understand of what I mean.
The problem comes in on the joining of the wall. The wall length and area is calculated based on the center line so when walls are joined that center line is now shorter. This can be seen easier when you create really thick walls and want to compare internal/external wall finishes vs center line.
This is also impacted by joined type, butt or chamfered (can’t remember right name).
In most cases I was happy with the tolerances and it ‘sort itself’ where in some instances it’s more and other it’s less. And I would add a waste calculation which increase the total above than what is scheduled.
However, to get it really accurate, I would look at Dynamo and build your own formula’s and input into a parameter on the element and schedule that.
there was an Autodesk University class on guys talking about the technical ins/outs of this and if I remember correctly they had some app that did this or dynamo.
@10dbim3 wrote:Greetings,
I'm trying to figure out a way to get the correct wall length once it has attached to a wall. I need to do this since it it gives out incorrect length and hence an incorrect area calculation when walls are joined. Also is there a workaround in dynamo to solve this issue.
Not sure I follow. How is Area incorrect (or Volume for that matter)? Area and Volume is removed at union.
as shown in the picture. the area is correct but the length of the wall is incorrect when I take wall schedule.
You can also use a calculated parameter to figure out the length on the face of the wall by using the formula "Area / Unconnected Height". In the Pic you can see the difference between the length parameter and the "Length on Face" parameter and how it relates to the wall.
