Wall Layers Not Showing Properly
michaelabman456
Message 1 of 20
michaelabman456
I've been trying to change wall settings for a solid hour to figure out why my wall layers aren't showing up in fine or medium detail levels, and am completely giving up.
The cut plane cuts through the wall, the wall is tall enough to make it to the cut plane.
The only wall override I have set up is for a keyplan view template, the walls I want layers shown in are not in any view templates. I have created a view template and assigned these plan views to it and still did not solve the issue of visible layers.
I am very lost as to what the issue could be so any help would be great 🙂
Replies (19)
Message 2 of 20
Is the wall less than 6' tall?
Message 3 of 20
michaelabman456
All of the walls are min 10' tall.
Message 4 of 20
Are they created in a previous phase?
Message 5 of 20
michaelabman456
Some are existing walls that also don't show layers while in the existing phase, others are new walls that don't show layers  in the new construction phase.
Message 6 of 20
Share your model here.
Message 7 of 20
Have you taken into account the Phase Filter Graphic Overrides?  Set View Phase Filter to "None" to see if that's where it's coming from.
Message 8 of 20
michaelabman456
Looks like it was a computer problem, not a revit problem and everything's showing properly now.
Message 9 of 20
Which computer problem?  PEBMAC? PEBCAK? ID10T?
I get those too.  😉
Message 10 of 20
tleyendecker77
Observer
Observer
I'm was experiencing a similar problem with my walls that are 2'-6" tall and my Cut Plan at 8". Why does this matter? If I increased the wall height to 7' it displays as expected.
I changed my View Range "Bottom" to -4'-0" and "View Depth" to -4'-0" leaving the "Cut Plane" at 8", and the 2'-6" wall appears with wall layers, as expected.
Message 11 of 20
_Vijay
what is the Revit version you are using?
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
Message 12 of 20
tleyendecker77
Observer
Observer
Revit LT 2025
Message 13 of 20
_Vijay
Can you able to share the sample file with that wall.
Vijayakumar
Head of BIM
Message 14 of 20
tleyendecker77
Observer
Observer
Here's the file.  The views that show the area are "New - First Floor - Bedroom - 8"" and "New - First Floor - Bedroom - Callout 16"".  Visually, it looks correct now, but if I left the View Range at the defaults I only saw the boundaries of the wall.
Message 15 of 20
_Vijay
@tleyendecker77,
I’ve reviewed your issue and couldn’t find any major problems in a similar setup. A few things you can check:
  1. Element-level graphic overrides – Did you apply any visibility overrides directly on the wall elements in the view?
  2. View template settings – Make sure the template doesn’t have a filter overriding the wall cut patterns or detail visibility.
  3. Material settings – Check if the wall layers' materials have appropriate cut patterns assigned. Sometimes, missing or white patterns can make it look like layers aren’t visible.
All three of these methods worked fine in our test file. Please double-check them and let us know your results. Happy to help further if it’s still unresolved!
Vijayakumar
Head of BIM
Message 16 of 20
Walls less than 6' are considered pony walls so they are not shown with layers even when the cut plane cutting the wall. Set the top of the wall to be associated with the level and top offset to the height you want they they will be cut properly.
Message 17 of 20
RDAOU
Layers of walls which are shorter than 6" show perfectly fine when they intersect with the view range's cut plane...Wall below is 1.3" high and cut plane at 1"  (without changing bottom range or view depth which would potentially mess up the visibility of other elements) Just cant open the uploaded file which has been created in a later version
Message 18 of 20
tleyendecker77
Observer
Observer
Thank you.
Message 19 of 20
Vom2007
I had the same issue, and checked these three sets of settings. But they turned unsufficient, even though important. Next i checked the Detail Level setting for the section view. By default it had been Coarse. Its change to Fine or Meduim solved the problem
Message 20 of 20
GHASEM_ARIYANI
hi @michaelabman456
1-Several factors can cause this issue:
2-Ensure the wall height is at least 2 meters. Walls shorter than this may not display layer details.
3-Ensure that the Detail Level in the current view is set to Fine.
4-Confirm that the wall is not in a different Phase.
5-Verify that the correct Design Option is active (if you are using design options).
6-If you used Create Parts, set the Parts Visibility in Properties to Show Original.
7-In VG (Visibility/Graphics), ensure that the option 'Non-Core Layers' is enabled under the Walls category.
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
