Wall Layer Extension
revit1980
Message 1 of 9
revit1980
Hello
Only, I am planning to extend the outer layer of my wall in plan view not in section. how i can do?
Please see the sample below
Thanks in Advance
Replies (8)
Message 2 of 9
PhilvK
You can't extend a wall layer in plan like you can do in section. In cases like yours I just another / separate wall type for the finish I want to extend. I think you can also use 'parts', although I haven't done it that way.
Message 3 of 9
@revit1980 wrote:
Hello
Thanks in Advance
Why?  Sounds very strange.  Where's this "Section" being placed?  Can you post a screenshot of the "Section" View?
Message 4 of 9
revit1980
It is placing on the corner with the column.I asked if there is any  possibility.Basically joining with structural column works very well But I dont know how  can i do if the Structural Columns are linked as seperate rvt.
Message 5 of 9
hmunsell
unfortunately the normal thing I would recommend only works in sections, not plan.
this is not ideal, but you can remove the exterior layer from your wall and place it as a separate wall. you would then have the ability to cover the column.
https://autode.sk/3b7klQb
Howard Munsell
Message 6 of 9
hmunsell
You could also use Create Parts to do it too i guess.... I don't usually like that method though.
https://autode.sk/359xeFt
Howard Munsell
Message 7 of 9
revit1980
Thanks for the captured screen casts.
Message 8 of 9
hmunsell
My Pleasure....
I have been told I "write like I talk" (which is all over the place) so I find it easier to show when I can :-).
Howard Munsell
Message 9 of 9
smruti_kadakiaEQZJ3
Community Visitor
Community Visitor
If the layers of the wall are unlocked. Then you can only select the layer (by pressing tab) and extend in the plan.
