Hi all, is there any way to use Wall Joins tool to work on section? I have used it on plan view but not sure what's the best way to proceed here. I attach an image of what I have know and a sketch of the desire done.
Many thanks.
Many thanks.
Solved by lama_aqel88. Go to Solution.
hi,
just use join geometry tool to join wall and floor.
and in floor and wall structure, check layer functions to be the appropriate function.
structure fuctionin floor join with structure function in wall
finish with finish and so on.
hi,
I joined wall and floor on section with geometry tool (please see image attached) but insulation of wall is not continuous with insulation of floor as desired. How do we achieve this?
@Anonymous
hi,
please find the attached images about the right arrangment of layers.
@Anonymous
hi,
