Wall joins in material takeoff
Laura.Negoita
Laura.Negoita
Community Visitor
Community Visitor
ello, i have a little question, i am trying to do a material takeoff schedule, and noticed that the wall finishes are calculated regardless the wall joins. See first image a simple wall with an interior finish area. After other walls are drawn, the wall finish area should be minus the wall join* wall height, but in the end the quantity is the same as before. On a large project, there is a big difference in material takeoff.
Can somebody suggest a more exact workaround? 🙂
Ilic.Andrej
Its not just about the joins, the wrapping of the finish is not calculated. You need some hard-core plugin to make this work.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
What about Parts?
constantin.stroescu
You can use an Addin of Revit- free for subscriptioner : Buildingbook Extension , a part of Quantification...it will solve the problem.
Constantin Stroescu
Laura.Negoita
Community Visitor
Community Visitor
I just manage to find the 2016 version,  where can i find the 2018 version?
Thank you!
constantin.stroescu
if you ask me where can you find Roombook Extension, then ,you have to go to your Autodesk Account > Management > Product Updates....you'll find it there ...(for Revit 2017 and Revit 2018)Image 1.png
Constantin Stroescu
Ok, but.... I'm working with IFC... this app will not work.
Considering IFC, there'is nothing to do.... ?
I know that i can use PARTS, it will calculate correctly.. but, parts dont turn in the wall...
