Wall Joins/Configuration Bar Grayed Out
- Mute
- Permalink
- Report
I would like to employ the of Clean Join/Don't Clean Join function to indicate where walls stop. I can hover over an intersection but cannot seem to select one and the configuration bar remains grayed out.
Also, materials with dissimilar cores (Wood Studs [1] versus Metal Studs [1]) will show a line separating the cores at the intersection (with first wall drawn apparently having precedence and shown going thru the second wall), but walls with the same material structure, even with different structural width (4" studs versus 6" studs) will join with no distinction between the different wall types.
Also, the intersection formed by walls that cross, with neither wall actually being broken, cannot be detected by the Wall Joins command. The gray selection box does not appear near this intersection and using tab will jump around close intersections but never finds this one.
It would be nice to get the Wall Joins command to behave and be able to use discrete Clean Join/Don't Clean Join as required. Any suggestions as to what I am missing with this command would be appreciated.
