Wall Join Problem
Wall Join Problem
PhilvK
Advisor Advisor
Wall Join Problem
PhilvK
1 and 2 below are all the same walls and at same height, no base extensions. The ones at 1 won't join, but do join at 2 when I copy them over. Any ideas why please?  Nothing above them.
vitorbortoncello
Probably because when you copy, new walls are created with the 'Allow Join' status, which I believe is causing the issue shown in Image 1 where the walls are not joined (Disallow Join).
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
PhilvK
I'm not sure if that was the issue, but I recreated them making sure the Allow Join was checked. Works fine! Thanks.
