- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, i am currently working on a project for my high school architectur class and am having issues with revit.
So far i havebeen designing this wall that can bee seen below. The layers that consist of air would be filled when i embedded the all with two curtain walls; one for the furring and one for the framing. For the installation-room behind the gypsum wall board and for the mounting of the outside cladding, i used a series of 45 x 45mm sweeps. I also used a sweep for the skirting board(not in picture).
However when i draw up a wall with an egde, and try to reveal the parts i get the following error: "Wall part could not be properly adjusted for join condition. Geometry may be inaccurate."
If i then click ok and ignore the error, it does not join properly:
I do not undersatnd why this is, and how to solve it, since i have not used Revit before. Has anyone else had this happen or understand it / know how to fix it?
Best regards,
Stinus Jørgensen
PS: Also thanks for all the help the people on here have given me, it is very nice.
