Wall Fill Pattern Reversed in Section View
masterbuilt1
Observer Observer
masterbuilt1
Observer
Observer
Hi!
So I'm drawing a concrete foundation wall with brick veneer sitting on a brick ledge.  For some reason the fill pattern reverses the materials in section view depending on orientation of the wall.  I've inserted a snip for demonstration.  in one orientation the fill patterns are correctly showing a concrete wall and brick ledge with brick veneer.  When I simply flip the orientation of the assembly, the fill patterns incorrectly reverse showing brick for the wall and ledge with concrete for the veneer.  What's going on here?  Thanks, Kevin
nicholas_seibert
Hi kevin,
I tried to reproduce this with a simple case but cannot.  Can you share a file where this happens?  Maybe some more details around how the walls are joined or not joined and how are the assembled together so i can try to reproduce.
Thanks!
Nicholas Seibert
Principal Revit QA
