Possible to Subregion from Split Surface - Topography
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
a00812364
1404 Aufrufe, 2 Antworten
Hello Everyone,
I was wondering if it's possible to create a 'subregion' from a previously 'split surface' from the topography.
Scenario:
After generating the topography, we created a road with 'split surface'.
The reasoning behind his was to set the road topography down about 6" to visually create a curb.
We now would like to move the road, but since the split surface is a set of points (not lines), our only solution is to merge both surfaces, and redo the road.
Is it possible to go from a split surface, to a subregion in a merged topography?
Is it possible to generate the perimeter of a topography? (allow us to copy and paste lines, then adjust them in a subregion)
Thanks!
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: a00812364
Maybe you can save your work. That is make the Split Surface into a road and put curbs to it.
What I'm talking about is Exporting the Split Surface to DWG and then Importing the DWG into an In-Place Massing Envirionment to create a Mass onto which you could apply a Roof by [Mass] Face(s).  The Roof would be your Road.  You can use the Gutter Tool on it to make Curbs.
FWIW.
...this PDF describes in detail the workflow I'm referencing:
http://aucache.autodesk.com/au2013/sessionsFiles/3340/913/handout_3340_AB3340_Make%20Hardscape%20Fol...
Nachricht 3 von 3
- Export the site plan with the splitted surfaces to DWG
- Merge surfaces
- Link the DWG in the site plan, turn on Wire Frame
- Create subregion and pick lines from the DWG link linework
