Hi everyone, is there a way to cut or do an opening diagonally on the wall?
On the right side of the image there´s a plan view, in wich the CAD file shows that the wall shpud have a diagonal opening or cut. How can I manage to do that?
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Gelöst von BDMackey. Gehe zur Lösung
This can't be done with the Wall opening command but you can create a family with a void that will do what you need.
I have attached one for your reference
