- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
Can someone tell me why REVIT LT decides to blank out a single wall (like it's in course view once I have added an additional profile the wall to make a hole in the wall? This only specifically happens when the walls base constraint starts on the level below and I attach to roof 2 levels up.
As indicated on the image viewing on level 2. The red ring has the issue where I have attached the wall to the roof which is base constraint is on level 0 and I get a blank wall.
Also, it does not do the above problem if I use the geometry cut command, however as this is LT you cannot create something to be cutting piece easily.
While I have found a workaround by coping the wall to the upper level as shown in green. Just want to know why it happens.
I am in detailed view.
