Wall composition lines not showing, although patterns are showing
Hello professionals,
In plan views, the lines separating wall materials (or layers) are not showing. There are no overrides, no view template.  The patterns are showing, just not the lines. Please see the attached screenshot.
Very much appreciated
Francois
Revit 2018 on Windows 10 (Run on Bootcamp)
- VG > Check Walls > Common Edges
- Or someone use <Invisible> linework on them
Thank you for your reply. There are no overrides for walls or lines in VG. I have attached the VG image.
Click on the plus sign next to Walls to expand the category.
That worked! Thank you very much, I really appreciate your help.
