I have a situation linke that. I have some construction slab. Than i have walls situated on this floor(1). On this structural floor there are some finishing layer(2). When I put any doors in teh wall, below there still remains part of the wall(3). How to remove it?
When I add additional void in the family, below the doors, and then try to make cut between the wall and doors, revit says it can't do it.
When I extend door void in the family, Revit set the lowest point of this void as a reference level and the whole doors goes up.
Any suggestions?
have you tried making an additional void extrusion constrained to the door width and the wall thickness and then have its depth on a parameter. set the default on it so that it is above the floor level and can cut the family host wall, but then when it is in the project you can set the void so it cuts the wall below the door.
Sounds like you want to utilize Layer Extension.
Here's how:
