Wall Based - Default Elevation parameter - Group Origin Level Offset
- Mute
- Permalink
- Report
Hello there,
I am having a problem with elevations of wall-based families when there are in a group while changing the Origin Level Offset of the group.
All the wall-based families (except the ones that have Sill Height and Head Height parameters such as windows and doors) have default-instance Elevation parameter. When they are in a group and you change the Origin Level Offset parameter of the group, the Elevation parameter of the family changes randomly and not at all adjusted/relative to the change of the group offset.
Is there anyway to fix this other than loading a group with its owned levels?! Can I somehow connect the Elevation parameter to the wall instead of the level?!
P.S. I only tested it with Generic Models and Speciality Equipments as categories.
Thanks in Advance š
