Wall and column issue
Message 1 of 8
wall-column.JPGHi guys,
I have some issue on wall and column.
the wall is trimmed whenever I aligned the edge of the wall to the column.
and the column is changing the hatch similar with wall.
I have attached the screenshot which supposed to be the result on the right image.
TIA guys
Accepted solutions (4)
Replies (7)
Message 2 of 8
Ilic.Andrej
If you want to model like shown on the picture to the right, use structural columns instead of architectural. Another option is to select wall ends , right click and "disallow join".
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Message 3 of 8
You are using the Architetural Column. In this case, the column Always get the wall material and hatch, even if you select another material in column configuration.
I suggest you change the Architetural Column for Structural Column, in this case the elements don't do the automatic join and don't mix the materials.
Message 4 of 8
ennujozlagam
Pick your column  > edit family > in the properties > untick join geometry > save as to another filename or save as same name > load into your project > and change the old column with revised one. Thanks
Message 5 of 8
Hi guys, thanks for all your reply.
Unjoin geometry and disallow join works well.
Now I can sleep.
Smiley Happy
Message 6 of 8
ennujozlagam
@Anonymous  hello, that was my suggestion to you. thanks
Pick your column  > edit family > in the properties > untick join geometry > save as to another filename or save as same name > load into your project > and change the old column with revised one. Thanks "
Message 7 of 8
Corsten.Au
Wall Column Joining behaviorWall Column Joining behavior
Hope this will help you
Cheers!
Corsten
Building Designer
Message 8 of 8
Thank you to all of you guys.
Really helpful your suggestion
This is the best site
Smiley HappySmiley HappySmiley Happy
