so I am using masses as Lego to plan a group of buildings within a complex.
I used masses and gave them a color through material.
There are many different levels in different parts so I did not use levels to generate floors. I just placed those masses as I wish them to be arranged and changed their material by hand.
Questions:
How can I give a specific color - related parameter for example residential-yellow ..?
How can I get the floor areas in a schedule according to use?
Thanks!
Solved by RDAOU. Go to Solution.
@tareqathamneh6QW84 wrote:
Questions:
Reply to Question 1:
Several ways, you can use for instance
Reply to Question 2:
Depends on how you modeled the mass.. but as a general rule anything which has a volume and you have given a Height parameter => you can derive area using calculated value
One Option would be
Alternatively Options:
