Void visibility
drenL5229
Void visibility
drenL5229
I have a problem I don't know how to solve. I am using a void to cut an angle in a line based profile. I want to have my void not visible if the angle is 0 as it would not have to cut anything and I don't want any errors in my family when I do set it to 0.
It is an instance based parameter. I wanted to set it off with an IF statement but I am having errors for "circular..".
Basically, how to turn off the void when I set the angle at 0.
I appreciate your time.
Replies (11)
curtisridenour
You should use a yes no visibility parameter. Also you should set a parameter to the angle that has a formulat that never goes to 0 so it does not snap.
_Angle = if(Angle=0,1,Angle)
drenL5229
Actually I want to have the ability to set it at 0 as well, snap, as you said.
So, if(Angle=0, Void (off), Void)
I hope this helps.
curtisridenour
Post your family here. I can take a look.
probably more like this though.
Void = if(Angle =0, 1=0, 1=1)
mhiserZFHXS
You'll need a parameter for you to actually control the angle, and then a parameter that is linked to your voids angle. For the parameter controlling the void, you'll need an equation like :
If (Angle=0, 45, Angle)
This makes sure your angle parameter doesn't break.
Then, for your visibility parameter, have an equation that says:
Angle>0
This will hide your void if the angle is zero, since the voids angle will actually be 45, or whatever number you decide.
drenL5229
Find it attached below.
Thank you!
curtisridenour
see below and attached.
curtisridenour
Angle>0 is a more elegant solution.
mhiserZFHXS
You don't need the if-statement for the visibility parameter. It just needs to be:
Thickened slab angle > 0
You don't need any extra parameter or formula.
drenL5229
@ToanDN thank you!
It looks obvious now, so basically put it outside the reference line so that the extrusion has always 4 sides and we don't have to work with triangles, which I did and it made everything more difficult to figure.
Thanks!
Correct.  This is the method I used in older Revit versions, when we didn't have the luxury of the Cut geometry parameter for Void.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
