Void Polar array is not parametric as in height ?
firas007noori
Message 1 of 21
firas007noori
Greeting,
I am trying to make a parametric column that has a vertical groves in it, I made the circular extrusion of the column as a cylindrical shape by the use of extrude command and locked the upper and the lower edge of the column to two newly create reference planes? flex it, it work perfectly, then I added a new extruded cylinder but this time as a void, and I made a polar array of the void around the center of the solid in order to make parametric groves, and when I lock the upper edge and the lower of the void, it works but it then cause errors if I try to flex and change the lower and upper edges of the voids??!!
I tried to go around this issue by not depending on reference levels and use the "Extrusion Start and end value" and add a parameter to control them, it was so successful till I changed the upper and the lower levels!! it always compare the controlling parameter to the previous levels, and I tried my best to use any method to use a reporting parameter to collect the real value of the levels and return it to be used as a height! and I failed again.
Any help will be really appreciated,
Best Regards,
Firas S. Noori
Firas Noori
Replies (20)
Message 21 of 21
firas007noori
Have a nice weekend too 🙂
Firas Noori
