Visible Annotation Lines
dm0144
dm0144
Hello everyone
I have window family, which is face based and I use it as a floor cut.
How can I make the annotation lines within the family visible in floor plan with the view range set to "Asosiated Level"?
If the view range is set to assosiated level, the lines are not visible on floor plan, since they are on the same reference plane as the floor.
Add a vertical model line in the family,  set it to invisible subcategory.  Or add a ref plane slightly above the level in the family to host the symbolic lines.
dm0144
@ToanDN what do you mean by the first suggestion?
The model line is so the family has something captured by the view range in project.
dm0144
@ToanDN Thanks!
