VISIBILTY graphics
VISIBILTY graphics
VISIBILTY graphics
I'm creating some shop drawings. I have taken a plan view and made a copy. I'm trying to edit the visibility graphics and get rid of these lines. I'm not sure what category they are under the VG. It looks like a column line but it's not. Attached is a photo of the line i'm trying to get rid of.
Are you talking about the "Reference Planes" (under "Annotations" in VG)? Or, the "Grid" Line (also under "Annotations")?
ennujozlagam
@Anonymous hello, it just a reference planes you can easily hide from VG as mentioned by @barthbradley or you can easily delete it ( by using your TAB in your keyboard to select ) if you need to. thanks
Corsten.Au
Hi
little trick to check the categories..
Select the element
Right Click and OVerride Graphics in View : By Category
That will open up this dialog
Clicking Open the Visibility Graphics Dialog will  reveal exact category whether
its Model or Annotation..
The one you are looking for is " Annotation Categories" _ Reference Planes..
If you are using linked model then you have to switch it off in Revit links..
Hope that ll help you
Cheers !
Corsten
Building Designer
